header bolts?
Old Jun 6, 2005 | 03:27 PM
meth's Avatar
Default header bolts?
anyone know offhand how tight the bolts should be. the ones that bolt to the engine?
mine are on super tight, but i just read a post where someone said theirs were easy to get off.
sorry guys i don't have a helm.
thank you.
Old Jun 6, 2005 | 03:33 PM
sebrings2k's Avatar
23 ft/lbs if I remember correctly.
Old Jun 6, 2005 | 03:42 PM
meth's Avatar
wow, thats it. i better go loosen mine tonite then,
thank you.
i will leave this open in case someone wants to verify.
but thank you.
Old Jun 6, 2005 | 03:52 PM
Kel's Avatar
Kel
23 ft lbs is correct.
Old Jun 6, 2005 | 04:01 PM
meth's Avatar
well, that's 2.
i swear they were super hard to take out, and couldn't have been 23 ft. lbs from the factory, but i will loosen them.
thanks.
Old Jun 6, 2005 | 04:04 PM
sebrings2k's Avatar
WD40 is your friend
Old Jun 6, 2005 | 06:22 PM
cdelena's Avatar
Originally Posted by meth,Jun 6 2005, 06:01 PM
well, that's 2.
thanks.
I would not fool with them if everything is together and not leaking. Its very hard to get a clean torque reading on those bolts and they probably heat seize a bit so they seem tighter when you take them off. I have always done them by feel and have have not had or expect a problem.
Old Jun 6, 2005 | 06:39 PM
SIIK2NR's Avatar
23 ft lbs with a torque wrench to ensure even pressure across the header flange.
Old Jun 6, 2005 | 07:25 PM
meth's Avatar
i've actually had them on for about a month with no problems. i am just paranoid they might be too tight. what are the odds at this point that one can snap from normal driving from overtightening.
thanks guys.
Old Jun 6, 2005 | 07:56 PM
cdelena's Avatar
almost zero.. don't worry about it.
