Headlight cut-off beam dull-looking?
Old Nov 17, 2011 | 10:51 PM
SixSigma's Avatar
Default Headlight cut-off beam dull-looking?
I finally got around to adjusting my headlights tonight but I noticed the drivers side cut-off isn't as sharp as the passenger. I also can't seem to align the beams perfectly. I know the drivers side headlight was replaced at one point so could it just be some sort of manufacturing defect in the assembly or even the bulb?
The first pic is the drivers side (you can see the beam fade away to the right), second is the pass. and the last is both as best as I could adjust them.
Old Nov 18, 2011 | 12:17 AM
Froth.'s Avatar
Honestly they look find to me...They're not supposed to be perfectly straight, They step off to the left to keep from blinding oncoming traffic.
Old Nov 18, 2011 | 04:15 AM
takeshi's Avatar
They're not supposed to be. Yours are normal.
Old Nov 18, 2011 | 06:54 AM
Saki GT's Avatar
I think he's talking about the cut offs aligning right and left - yes your headlight could be adjusted right-to-left a bit but it doesn't really matter.
Old Nov 18, 2011 | 02:24 PM
SixSigma's Avatar
Yes, I realize there is a step-up built in. The light output just isn't as powerful or as clear from the driver's side light. It's more centered where as the passenger's output has a wider, more proportioned range. You can see in the last pic how the light kind of falls off on the left but its fine on the passenger side. I'm probably just being anal, mainly because I can't see around corners as well as I can in my friend's car, but I just wanted to see what you guys thought.
Old Nov 18, 2011 | 04:50 PM
sillyboybmxer's Avatar
Well first of all.....your bulbs are old. After 1500hours hids are only 50% of their original brightness. The easiest way to align is to cover up each light with a heavy blanket to get a real idea how the lights blend together.
25ft from a wall, the top of the passenger side cutoff should be 2.1inchs below the center of the headlight and the driver side should be slightly lower just as a guide to follow.
Old Nov 18, 2011 | 04:52 PM
Those are my old bulbs before picture I swapped just for reference those have about 1000 hrs on them
Old Nov 18, 2011 | 05:18 PM
StudMuffin's Avatar
Just sent my headlights to customlightz for clear lense change and adjust the color and cutoff line. Can't wait till they come in
ungucpho
Feb 6, 2013 05:06 AM
rai
Oct 22, 2005 08:00 AM
AustinS2k2003
Aug 4, 2004 10:01 AM
MyEeek
Dec 23, 2002 11:15 AM
MarkS2K
Feb 26, 2002 10:21 AM
