heat dont work
Old Dec 20, 2006 | 06:05 PM
S_NeWb's Avatar
Default heat dont work
anybody knows anything if AEM ems turbo charge do anything to the heat a/c system? i currently have AC only no heat. even after 15 mins.
Old Dec 20, 2006 | 06:27 PM
Spec_Ops2087's Avatar
Did you flush the coolent? Probably air bubbles in the system if you did.
And I don't understand what "AEM ems turbo charge" is. Do you mean you just had an AEM EMS installed in a turbocharged car?
Old Dec 20, 2006 | 06:46 PM
S_NeWb's Avatar
yes AEM EMS on a turbo charged. i swap out radiator. its that consider a coolant flush? sorry i am new at this. is there something i should look at?
Old Dec 20, 2006 | 08:15 PM
Slows2k's Avatar
You've got air in the Cooling System. There are 2 bleed locations, 1 on the H20 pipe that runs across the firewall, the other on the front of the intake manifold.
With the engine cold, open the radiator cap. Pick up the front of the car with a floorjack/jackstands to make the radiator the highest point in the cooling system. Loosen the bleed screw on the manifold, pull the rubber cap off the H20 pipe on the firewall. turn the ignition to on, and the heater knob to full hot.
Air should come out of both fittings, keep the radiator full of coolant. start the engine and close both bleed locations after coolant streams from both. You may have to repeat bleeding air from both locations with the engine running to get all of it out.
Old Dec 20, 2006 | 09:20 PM
Old Dec 20, 2006 | 09:27 PM
MikeyCB's Avatar
Now that's some good advise...I'm impressed
Old Dec 21, 2006 | 03:43 AM
S_NeWb's Avatar
thx a lot.
Spec_Ops2087
May 15, 2017 12:02 PM
js2000typegt
May 17, 2014 10:43 PM
D1sclaimer
Jul 11, 2010 04:09 PM
DrewKC
May 16, 2010 08:35 PM
Silver S2k4
Mar 11, 2008 03:21 PM
