Heat Shield Removal
Old Oct 13, 2006 | 09:17 PM
Lok's Avatar
Lok
Default Heat Shield Removal
Hello everyone,
I am having trouble to remove the heat shield for the engine torque damper installation. I remove the three screws up closer to the front end of the car but the heat shield is still stuck? Seems like something is holding it on the firewall?
Thanks
Old Oct 13, 2006 | 09:22 PM
innovation's Avatar
theres still 1 screw left by the back of the heatshield. hard to get to
Old Oct 13, 2006 | 09:24 PM
Ustemuf's Avatar
if it's not tightened too much i found you can just pull the heat shield UP off of that one because it's not completely bolted in, it's kind of like an upside down U that locks onto a bolt...so i think they designed it with this method in mind.
when i reinstalled it i just put that part of the heat shield on first by sliding it down behind the nut, then i tightened in the others and worked fine!
Old Oct 13, 2006 | 09:36 PM
Lok's Avatar
Lok
thanks!! I was wondering what clinging onto the shield!!
Thanks!!
s2000maniac
Sep 8, 2011 07:28 PM
AlX Boi
Apr 4, 2007 01:56 AM
