Heater core valve?
Old Oct 14, 2010 | 03:07 AM
Muscle Cars Blow's Avatar
Default Heater core valve?
Just bought my s2k. Apparently the heat doesn't work cuz there Is a valve that is closed. Can't find it can anybody show a pic of where this is located?
Old Oct 14, 2010 | 04:34 AM
ahrmike's Avatar
1) dont drive the car til you figure this out, it might be a un-bled bubble in the coolant. and if it is you WILL overheat the car and blow the engine.
2) I dont know of any valve that controls the heater core, someone else will chime in if they have more knowledge..
3) Its possible that the heater core is bypassed..
Old Oct 14, 2010 | 05:42 AM
Just drove it 1145 miles, it's some sort of bypass I was just hoping there was one location it was always done at and I could remove it.
Old Oct 14, 2010 | 03:38 PM
ahrmike's Avatar
Follow the heater core backwards. MAke sure you actually HAVE a heater core and also that its not leaky. I bypassed my camaro's heater because the hose blew and started leaking, being in hawaii I didnt need it either..
If I were you, I'd trace the line back from the heater core... Did you need a schematic? Look on
hondaautomotiveparts.com for a quick schematic..
Old Oct 14, 2010 | 04:16 PM
zeroptzero's Avatar
there is a valve under hood along the firewall to the right of the battery and left of the valvecover , when you put it to heat the cable pulls the valve , when you put it to cold the cable pushes the valve. You can tell if it is working by changing the heat/cool position and seeing if the valve has moved, easy to see. If it doesnt move or if the cable is disconnected/broken you will know if it is a problem. You need to have the ignition on when changing temps as the cable actuator is electrically powered.
Old Oct 14, 2010 | 10:54 PM
thanks guys, I'll take a look at it tomorrow and see how it goes.
dan_bourne
May 29, 2012 03:22 PM
ap1son
33
Apr 14, 2010 02:24 PM
REV_29K
22
Apr 4, 2005 04:55 PM
J.T
Sep 11, 2003 10:32 PM
