Help!!
Need to find acc. wire for viper 790 remote start. DEI and wiresoft show NO acc. wire, but we know thats not true. If anyone has found or knows where to find a acc. wire( not behind the radio) please let me know.
Thanks,
Matt
Thanks,
Matt
It will be in a big harness cluster under the steering colum. I think its BLACK WITH YELLOW STRIPE or WHITE STRIPE. Its one of the ignition wires. That or there are I think 3 different accesory spots in the fuse panel that you can use a female spade terminal to tap into I believe. Just get your meter out and test those wires!
some of the images don't work, but if you check out this library article on hardwiring the V1 - you'll find your answer.
https://www.s2ki.com/article/articleview/34/1/51/
