Help ?
Get your car up in the air and look at the rubber engine mounts, look specifically at the top side of them from under the car. you will be able to tell if they are broken. it's common for them to break
Car is your baby and you ride around on bald tires... i hope you don't have an actual baby
then i will jack it up and check the mounts. although i can tell you that the tires being bald and the car having a aftermarket raditor makes me believe it was boosted before -_- aka meaning wouldn't suprize me if it was motor mounts that are gone.
it's common for them to break and you can get them for about ~$50 bucks a piece used vs $150 at the dealer
just because your car has an aftermarket radiator is no indication of it being boosted, plenty of na cars have an aftermarket radiator. There are more obvious signs to tell if the car was boosted, like a capped off oil feed line, or signs from an intercooler being mounted
ok update: finally got the car on a left to check things out. looks like diff mounts are good no leaks or tears. also transmission mounts are good as well. checked them both. then took apart the shift boot and all the plastic around the shifter and everything checked out there as well. any other ideas of why this would be happening?
