Help ?
Old May 30, 2013 | 08:19 AM
  #21
slickdevil08's Avatar
Actully sorry forgot to mention that . My bald tires are gone got two fresh gt one Goodyear tires for the rear now. Also got then mounted and balanced and a full alignment
Sent from my iPhone using Tapatalk
Old May 30, 2013 | 10:20 PM
  #22
s2k-tilldeath's Avatar
Originally Posted by slickdevil08
Alright I have an update! Went to put air in the tire that looked low and discovered it should have 40psi and the right one had 16 . So that fixed the ride quality issue but yet the shifter is still shaking and also when I hit bumps it shakes even more? Any ideas?
Hey, the tires should be at 32psi and not 40psi.
Old May 31, 2013 | 10:13 AM
  #23
I have since fixed that issue
Old May 31, 2013 | 10:40 AM
  #24
realblag's Avatar
ok update: finally got the car on a left to check things out. looks like diff mounts are good no leaks or tears. also transmission mounts are good as well. checked them both. then took apart the shift boot and all the plastic around the shifter and everything checked out there as well. any other ideas of why this would be happening?
There are 2 engine mounts and 1 trans mount.
Old May 31, 2013 | 11:21 AM
  #25
s2000maniac's Avatar
Trans has 2 mounts
Old May 31, 2013 | 02:08 PM
  #26
realblag's Avatar
Der ... Lol.... Oops.
Old Jun 1, 2013 | 03:03 AM
  #27
Yeah that is my next thing to check hopefully this fixes the issue
Old Jun 2, 2013 | 04:51 PM
  #28
Lalasissyboy's Avatar
An upgraded radiator will not cause the engine to run colder in normal driving (well not to the point where the car wont even warm up) the guy you bought the car from put a low temp thermostat and/or fan switch in the car when he replaced the radiator. Thats why your car won't warm up all the way. If I were you I would switch back to a stock thermostat asap. There is no reason for it. Even hard core race cars have a stock thermostat.
Old Jun 3, 2013 | 05:27 AM
  #29
Ok he said e was building it as a turbo project but never got around to the cruel turbo so I'm thinking that too anyone know where I can get a stock thermostat at?
Old Jun 3, 2013 | 05:53 AM
  #30
jetboater's Avatar
did you clean your IAC (idle air control) yet?
