Help
Old Jan 13, 2020 | 06:08 PM
Rosasale's Avatar
Originally Posted by zze86
So car off you cannot shift. Car on it does let you shift?
No punctuation makes it hard to tell what you are trying to say.
sorry , so while the car is off I can put into gear not all the way in but there play once the car is on it doesn't let me put in gear
Rosasale's Avatar
Originally Posted by windhund116
Brake fluid bleed issue?
That the reason I swap the master cylinder
Old Jan 13, 2020 | 06:11 PM
Rosasale's Avatar
Originally Posted by engifineer
Do what Chuck said. If, when the car is off but in gear, you cant move it when the clutch is depressed, then need to determine the issue with the clutch. In that case, get under the car (on stands, safely of course) and get to where you can see the slave cylinder boot. You can pull the boot back or just feel it when someone depresses the clutch to see if the clutch fork is moving. If it is not, then you have either a clutch linkage (from pedal to master cylinder) issue or an issue in the hydraulics. If the clutch fork is moving properly (Should move all the way forward and backward when the pedal is actuated) and it is not disengaging the clutch, the tranny will need to be pulled to determine what is going on and to fix it.
Idk if is normal or not but when the car is on if I push the shifter into first it does not let me engage it but if I hold the shifter against first gear the car roll a bit
NoobKim
Apr 26, 2019 06:26 AM
Lovetodrive2000
May 14, 2018 05:26 PM
S2KP
Apr 1, 2018 07:23 AM
Arameh_S2K
Mar 5, 2018 02:58 PM
jbjb
Forced Induction For Sale
May 21, 2017 02:23 AM
