Help !
Old Dec 1, 2007 | 12:53 PM
hieu512's Avatar
Default Help !
I just got my car back from getting my top replace, alot of problem but I just notice that, there's a grey harness that's unplug but i saw that there's a wire plug, next to it so I just plug it in, fit perfect, but then there's a 2 pin red/yellow connector harness still unplug not sure where that go?
And can you guys tell me what does that grey harness next to the fuse box that i plug in do? the 2 pin connector also next to the fuse box
thanks for your help
Old Dec 1, 2007 | 02:11 PM
hieu512's Avatar
ok, found the 2 pin harness is for the hood pin, or extra senor
Old Dec 1, 2007 | 02:27 PM
NVMY4N's Avatar
Defrost for Hard Top?
your typing is confusing.
Old Dec 1, 2007 | 02:32 PM
hieu512's Avatar
i am sorry, but i see that there's a gray connect kinda big unplug, so then i look around i see that there's a white end, so i connect those together and they fit, right under the fuse box, and harness i see is 2 pin and that is red/yellow so i look around and i think it's hood pin, or an senor
thanks
Old Dec 1, 2007 | 02:36 PM
NVMY4N's Avatar
Probably not HT defrost then.....I misread or just thought it was up there the top is....since you had the top replaced.
Im not positive what it is......
Old Dec 1, 2007 | 02:38 PM
hieu512's Avatar
yea same here, i try searching on here, dont see it, but i know the other 2 pin harness is for, but i am not sure about the grey harness, it plugs right up to the white one next to it though so i guess somehow they forgot to plug it back in back just want to make sure,
Soul Coughing
Nov 10, 2013 03:35 PM
Suzuka_Joe
Jul 20, 2011 03:28 AM
hieu512
Dec 1, 2007 01:32 PM
hieu512
