HELP! Is this bad, and what can I do?
Appears to be a valve cover gasket leak. Clean the area really well and see if you can determine exactly where it's leaking after running the S. You can try retightening the valve cover to spec's, but you may have to replace the gasket itself to remedy the leak. Hope this helps!
I cleaned mine the last time I checked my valves. It stopped the leak. Just make sure you clean it completely, and polish the mating face on the head. You need to torque it in sequence too, otherwise it will bow slightly and continue to leak. FYI: it's more of an annoyance than a problem.
Whats wrong with the pictures?
