Help--both fans turn on at same time
Old Nov 1, 2010 | 09:34 AM
Orpheus's Avatar
Default Help--both fans turn on at same time
Hi,
Both fans are turning on at the same time: when I turn on AC, both will turn on, and when the car reaches ~95-96deg C, both turn on as well, and shut down together when the water is cooled enough.
I believe only one fan turns on when AC is turned on right? And when the water is too hot both turn on? Which fans are used for what and when? Sorry, I tried searching, but was not too clear, so I figured I'd ask here as well.
So, a little history: I believe before only one fan turned on for AC (the passenger side one), and I assumed that was correct. Then I noticed one day when the car was hot, the fans acted differently--I believe (but might be wrong) that the AC fan still turned on, but when hot, the other fan did not kick in. So, I wiggled the wiring around and both turned on, but then both always turned on at the same time.
This weekend, I took out the joint areas to rewire and found everything corroded. I put everything back together again with fresh wiring, and I believe I did a satisfactory job. There should not be any shorts. Yet, the problem remains.
Is there possibly a busted relay or something that I need to replace? Any help is appreciated.
Old Nov 1, 2010 | 11:01 AM
spets's Avatar
I don't have the manual with me, but I believe both fans should turn on when the A/C is on.
Old Nov 1, 2010 | 06:23 PM
fatjoe10's Avatar
With A/C on, both fans should run. With the car cold in the Key On Engine Off position, toggle on the A/C button and you will see/hear both fans spinning.
Old Nov 2, 2010 | 11:52 AM
Orpheus's Avatar
ah really? i must have confused myself then.
can you clarify for me--so you are saying there is never an instance where only one fan is on?
thanks.
Old Nov 2, 2010 | 06:46 PM
ahrmike's Avatar
Orph, Im not sure whats supposed to happen but I've never seen only one fan on in my s2000 also.
Old Nov 4, 2010 | 07:10 AM
osidis's Avatar
i just replace my radiator, fans, thermostat, hoses, fan switch with all mishimoto parts. This equipment is awesome. anyway, after the install last night, you need to test the equipment. one of the tests is to see if the fans (plural) come on. as i read further, it stated the both fans come on. hope this helps.
rikhemi
Jun 12, 2017 11:11 PM
OneSilverS2k
Apr 10, 2011 09:31 PM
tightcrap7
Oct 16, 2009 12:35 AM
ahrmike
Jul 21, 2009 10:13 PM
Purple Haze
Jul 29, 2008 12:04 PM
