Help- Car Doesn't Start Sometimes
Old Feb 20, 2013 | 12:56 PM
Jag528's Avatar
Default Help- Car Doesn't Start Sometimes
I swapped my clutch about a month ago and ever since then, every once in a while my car won't start. I'm thinking it might be a bad starter since we were working in that area when we did the clutch, but I'm not 100% sure. I don't think it could be the battery. Only other thing I can think of is bad wiring (again a lot of wires had to be moved/unclipped etc when I did the clutch) or maybe the solenoid. The symptoms are when I try to start it up I can hear two clicks from what I assume is the starter and I can hear the fuel pump. Nothing else happens, doesn't try to crank or anything.
The first time it wouldn't start was about a week after I did the clutch and now it has happened probably 5-10 times since. I've had to push start the car when it has happened, but I can't keep doing it because it can't be good for the clutch and trans and also because it's embarrassing asking people for a push lol. Any advise is appreciated.
Old Feb 20, 2013 | 02:17 PM
apme123's Avatar
Try taping the starter mine gets stuck sometimes, my battery is new. Mine only does it in cold weather.
Old Feb 21, 2013 | 05:33 PM
alphalanos's Avatar
sounds like the starter
Old Feb 21, 2013 | 05:46 PM
Jag528's Avatar
I grabbed a rod that I can use to tap on the starter if it doesn't work. I guess if I use it and then the car starts, I can assume the starter is going bad.
Besides that, how can I be sure the starter is bad and it's not wiring or something like that? I'd just hate to drop all that money on a new starter and still have problems...
Old Feb 24, 2013 | 11:37 AM
Jag528's Avatar
It just happened again so I tapped on the starter and it started right up. Can I safely assume that the starter is bad or could it just be misaligned or something from the clutch swap?
Old Feb 24, 2013 | 11:19 PM
apme123's Avatar
clean all the starter contacts, starters do get old, napa has 3 different levels
of rebuilt starters, get the highest one they have with new solenoid and contact points
Old Feb 24, 2013 | 11:20 PM
apme123's Avatar
I replaced mine, hasn't done it sense
Zerolagoon
Aug 2, 2017 07:02 AM
Soviet
Jul 12, 2015 06:02 PM
nickbest
Mar 25, 2013 09:35 PM
prorcracer87
May 5, 2007 07:04 PM
phillys2k
Apr 5, 2005 08:29 PM
