Help diagnosing engine rattle - TCT?
Old Dec 29, 2016 | 07:19 AM
MattZ28's Avatar
Default Help diagnosing engine rattle - TCT?
About 1000 miles after my Kraftwerks install, my engine has developed this rattling sound. It's definitely coming from the front of the engine and it's most noticeable around 1800-2000RPM. I initially thought it sounded like a loose blower belt, but adding tension makes no difference. Let me know what you guys think...
Old Dec 29, 2016 | 08:33 AM
Car Analogy's Avatar
Does not sound like tct to me.
One quick easy thing to rule out is a serp belt driven component, pully bearing, alternator, water pump, etc. Just remove serp belt, and see if noise is still there. Obviously don't run car very long like this, or it'll overheat.
Don't even need to remove serp belt. Just let it hang without tension from tensioner. It'll take all of 5 min to test this way.
If noise is gone with serp belt inactive, spim each pully by hand to find which one is bad.
Old Dec 29, 2016 | 09:24 AM
Billman250's Avatar
Active Streak: 30 Days
Active Streak: 120 Days
Top Answer: 1
There is a fast tapping that sounds like TCT frequency.
Old Jan 8, 2017 | 06:12 PM
MattZ28's Avatar
Installed a Billman Gen X TCT tonight and the rattling noise is fixed.
jyeung528
Dec 24, 2013 05:20 PM
chief_67k
Oct 7, 2013 02:51 AM
Spec_Ops2087
Jun 21, 2013 08:23 PM
diabolus2k
Jun 26, 2008 06:52 PM
