Help! engine bogs or hesitates
Old Sep 4, 2008 | 07:35 AM
SCCS2K's Avatar
Originally Posted by jkuamoo,Sep 4 2008, 12:47 AM
so what was the problem in your case?
Yeah, seriously, throw us a bone here. What did he do?
Old Sep 4, 2008 | 01:51 PM
JesseTES707's Avatar
same thing happened to my gsr
Old Sep 4, 2008 | 02:15 PM
SCCS2K's Avatar
and? did you find out the culprit?
Old Sep 4, 2008 | 11:14 PM
yoteru's Avatar
everyone has the problem, but no one has the solution? so this should magically go away?
Old Sep 5, 2008 | 03:50 PM
S2kBot's Avatar
comon porblem for s2ks.... this problem is cause by vibration of the motor on acceleration which make the connector that goes on you map senor loose cause misreadings from the map sensor.
go to honda and get the clip that goes on top of the map sensor and ties around the connector to make it tight.
some time you'll have to replace the map sensor too
i've install alot of the map sensors and ties on s2000's that comes to honda for that same complaint problem.
hope this helps
Old Sep 5, 2008 | 06:28 PM
SCCS2K's Avatar
S2kBot - would you say that my problem is the MAP sensor as well? Here's my thread: https://www.s2ki.com/forums/index.php?showtopic=627404
Note that I no longer think it's related to shifting, it's simply more obvious at lower revs (which is where upshifting usually puts me )
Old Sep 8, 2008 | 07:45 PM
yoteru's Avatar
i dont think mine is the map sensor, replaced it and go the tie, still does the same thing. anyone else know what it might be?
thanks
Old Sep 8, 2008 | 08:18 PM
Kirpich's Avatar
Fuel delivery (pressure, contamination), bad/dying injector.
Spark delivery (timing, weak), check spark plugs, _espicially_ torque of plugs.
But these would throw a MIL/CEL.
Bad ground somewhere? Check grounds. A bad ground rarely throws a CEL, and when it does, it's something really weird.
Old Sep 9, 2008 | 01:59 AM
INDYMAC's Avatar
A new air filter fixed this problem for me once. Have you tried this yet?
Old Sep 10, 2008 | 08:34 AM
yoteru's Avatar
[SIZE=7]Update[SIZE=7]
The check engine light just came on. it shows the code p0172 (system too rich)
Does anyone know what could cause this problem?
it also has 2 pending codes p0170 and p0128
Thanks in advance for any help!
