Help got cel P2a00
Old Mar 7, 2011 | 06:12 PM
azride1983's Avatar
Default Help got cel P2a00
I got the cel P2a00 O2 sensor primary. I ordered a new one. Can i just replace the old one and flash the ecu with flashpro and everything be ok? I read in the forum that i have to take it to the dealer so they can flash the ecu? Can the flashpro do the job to eliminate the cel with a new sensor? Will it be clip on affair for the sensor? Thanks
Old Mar 8, 2011 | 07:55 AM
Rubn1out4GudLuk's Avatar
Yes, u can do just that. Had the same code pop up a while back. Make sure the new primary sensor u get has the green shrink wrap on the wiring. Thats the revised sensor. Your bad one should have a blue shrink wrap on it. I did and it worked fine.
interesting FYI;
Your join date is the same day I bought and picked up my s2000, dec. 6, '07.
Old Mar 8, 2011 | 08:17 AM
Swiftoy's Avatar
I cleared the DTC code first in Flashpro then reflashed again, not sure if it was necessary but I did it anyway. I contemplated for a minute about getting a different sensor other than OEM but realized it wasnt worth it. The new part number is 36531-PZX-013. The sensor is basically a remove and replace.
unowned
Apr 11, 2021 08:19 AM
adriangb
Jan 26, 2018 06:17 AM
sloo2k
Nov 7, 2017 11:06 PM
4x4 freak
Dec 2, 2015 10:08 PM
barefoot
Feb 24, 2010 10:18 AM
