HELP! installing ARC air box
updates on the installation, I used hose clamp to tight down the ac-line b4 my new brackets arrives. it should be good enough for now. will post pix about the whole installation process later.
good to see you got it done!! Looks great in there. Post more pics though, gotta have something to show for all that work you did!!
I will admit, I was looking at that intake, but seeing all the hassle that was involved, I decided on the PRM. Start to finish wa 45 mintues!!! OH well, as long as you are happy, thats what counts!
Let me know if you need any more help!
John
John
heehee,
thanks.
the arc is actually not that bad, the trick is use spacers, as long as u don't care for a not-so-perfect fit. so the AC line won't be bent that much. Will post pix about the whole process after I have the brackets ready. The whole process takes about 3 hours. Also will have the dimention of the bracket ready this friday.
thanks.the arc is actually not that bad, the trick is use spacers, as long as u don't care for a not-so-perfect fit. so the AC line won't be bent that much. Will post pix about the whole process after I have the brackets ready. The whole process takes about 3 hours. Also will have the dimention of the bracket ready this friday.
xxvicxx
Jul 12, 2011 01:57 PM
S2KPUDDYDAD
Nov 17, 2004 02:38 PM
