HELP!! Installing Cusco Clutch ... Throw Out Bearing????????????
Old 06-19-2004, 11:45 AM
JohnsS2K's Avatar
Default HELP!! Installing Cusco Clutch ... Throw Out Bearing????????????
Installing Cusco Hyper Single Clutch ... OEM throw-out bearing will not fit through pressure plate ... Are we supposed to use the OEM throw-out bearing or a different one???
Please RESPOND ASAP!
JohnsS2K is offline
Old 06-19-2004, 02:17 PM
JohnsS2K's Avatar
Hey all you self-proclaimed experts ... speak up
JohnsS2K is offline
Old 06-19-2004, 02:35 PM
alexf20c's Avatar
Use the throw out bearing for that pressure plate.
alexf20c is offline
Old 06-19-2004, 02:37 PM
JohnsS2K's Avatar
Yeah, well which one would that be? OEM does not seem to fit and nothing came in the box eith Cusco clutch?
JohnsS2K is offline
Old 06-19-2004, 03:21 PM
JohnsS2K's Avatar
JohnsS2K is offline
Old 06-19-2004, 03:42 PM
honda9krpm's Avatar
I got an exedy. I think Cusco is just a rebadge of exedy.
The factory one should fit. It did on mine.
honda9krpm is offline
Old 06-19-2004, 03:45 PM
JohnsS2K's Avatar
[QUOTE]Originally posted by honda9krpm
I got an exedy.
JohnsS2K is offline
Old 06-19-2004, 04:10 PM
honda9krpm's Avatar
the s2k is a pull clutch
yes you have to force/pull the bearing through the pp
(I hope the pict help....sorry for the wrong angle)
Old 06-19-2004, 04:20 PM
JohnsS2K's Avatar
How did you force the throw-out bearing through the pressure plate fingers? By what method?
Thanks in advance for all of your help!
JohnsS2K is offline
Old 06-19-2004, 04:24 PM
honda9krpm's Avatar
I forgot to mentino that you should replace the bearing with a new one but other than that just wiggle it in and pull it through
My mechanic did it but I don't think there is any trick to it.
Quick Reply: HELP!! Installing Cusco Clutch ... Throw Out Bearing????????????
