Help! Issue with shifting
Old Jan 27, 2010 | 08:31 AM
ssmAP1's Avatar
Default Help! Issue with shifting
Hello everyone,
I am having an issue with shifting gears when the car is just starting up and even sometimes while at a stop light. The problem used to happen every once in awhile, but has been happening more often as of late and it would let me shift it into 1st or reverse if I let up on the clutch and then push it back down or if i force it into the gear. Now it feels like my clutch isnt pushing back at all, there doesnt seem to be much of a "sweet spot". The clutch is just really soft and it wont let me put the car into gear at all now. Any idea of what the problem could be? I'm leaning towards clutch
Old Jan 27, 2010 | 08:33 AM
Presto123's Avatar
check ur fluid?
Old Jan 27, 2010 | 09:10 AM
ssmAP1's Avatar
Thanks for the tip, anything else you I should check? I didnt have time to tinker around this morning but I'll be able to check a few things when I get home tonight.
Old Jan 27, 2010 | 11:01 AM
viets2000's Avatar
ditto on the fluid. Your master cylinder or slave cylinder could be going bad allowing fluid to leak and letting air in the system. This would create the "soft" feeling and eventually the slave wont travel enough to let you engage. Probably exaclty what you ran into
Old Jan 27, 2010 | 05:26 PM
JDMQuip's Avatar
I would change the fluid first and see if that remedies the problem. If that doesn't work then I would check the clutch master cylinder. And so on and so on...
Old Jan 27, 2010 | 06:14 PM
dales2000's Avatar
check inside the car for leakage from the clutch pedal coming from the piston. if it is leaking then the master cylinder is going.
nmehdikh
Jan 17, 2017 12:49 PM
guy13
Oct 30, 2013 01:27 PM
L4V15
Aug 20, 2012 11:27 AM
fireNYRgm
May 3, 2011 05:52 AM
BrandonS2K
Jun 17, 2007 08:59 PM
