help! just replaced brake pads...
Old Dec 9, 2005 | 05:46 AM
AllStock27's Avatar
Default help! just replaced brake pads...
ok, just a brief description... I replace the pads w/ oem pads, followed the instructions on the how to pg from the FAQ, bleed the brakes.... but when i drove this morning i noticed that the brake light is still on.. (as if i still have my handbrake still up)... I dont know if it mattered, but after i was done with the job, the car was parked at an angle all night, so my handbrake was on all night, does that matter? Pls help!
The car runs fine, dont feel any major drag, but need to know what is causing this.. help!!
Old Dec 9, 2005 | 07:13 AM
ianho's Avatar
Have you checked your brake fluid level?
ian
Old Dec 9, 2005 | 04:01 PM
Slows2k's Avatar
Low fluid is the most likely cause.
Old Dec 9, 2005 | 04:36 PM
kurt_bradley's Avatar
He may also want to check the float in the resevoir. If that thing catches, it can kick the light on.
Old Dec 9, 2005 | 04:46 PM
Slows2k's Avatar
You can't see the float or in the reservoir on a S2k, it's behind the baffles in the reservoir. The switch in the reservoir have been known to go bad, but it's unlikely since this just started after replacing the pads.
Chances are pushing the pistons back in the calipers pushed fluid out of the master cylinder. Then when the pistons where pushed back towards the pads the fluid left is now low.
Old Dec 9, 2005 | 05:09 PM
Race Miata's Avatar
Agree. In that case, he will have to worry about brake fluid eating out paint surface in the engine bay as well.
Old Dec 9, 2005 | 06:46 PM
AllStock27's Avatar
Ok guys, found the solution! i feel so stupid now! lol low fluid was the culprit... I thought the fluid was enough, but upon closer inspection, it was just a tad bit below the minimum line... To be honest, I didnt xpect the solution would be that easy, lol... Now i can say that the next time i do the brakes it would b a piece of cake... lol Thanks everyone for your help!
Old Dec 10, 2005 | 09:59 AM
CoralDoc's Avatar
Glad to hear the solution was so simple.
Just to add another tidbit of information, a friend of mine had his reservoir float go bad. That meant that even when the level was correct, the float sank down and turned on the light. And no, it wasn't stuck.
Old Dec 11, 2005 | 10:19 AM
Random1's Avatar
I have this case where the float gets stuck down, it appears to float fine once released. I have been able to pop it up, but eventually it gets stuck down again, mostly associated with ABS activation during autocross. I'm not sure why it gets stuck down, I'll replace the reservior and see what happens.
Old Dec 11, 2005 | 01:55 PM
Slows2k's Avatar
The reservoir isn't available seperately new. To replace the reservoir, you have to buy a master cylinder.
