Help Me Diagnose My Engine Problem
Old Jun 12, 2005 | 08:32 AM
PathNull's Avatar
Default Help Me Diagnose My Engine Problem
So I'm at a loss to explain this sound in my engine and thought I would put it out to the board.
For the past 3-4 months I've been noticing a clicking sound that rises and falls with the engine rpm. It's not associated with the drivetrain cause I can still get it with the clutch out. Imagine the sound a fan makes when you put a piece of paper in it, this sound is very similar.
It isn't loud and really becomes audible around 3k-4k RPM, especially when I'm driving next to a wall. Whats odd is that yesterday I changed my oil and it went significantly down (could it be the oil pump?)
From my investigation I'm not hearing it from the timing belt. But if I had to pick a side of the car it's on the right (looking out the windshield).
So, does anyone have any thoughts or other questions? I'm at a loss to explain this...and it wasn't here 6 months ago....
Old Jun 12, 2005 | 09:10 AM
SIIK2NR's Avatar
If it's "ticking" or "clicking" with the rise and fall of RPM's then I would recommend taking it to go get looked at.
Did you overrev? whats your driving style?
It's a timing "chain" not "belt"....
Old Jun 12, 2005 | 09:47 AM
Billman250's Avatar
Active Streak: 30 Days
Active Streak: 120 Days
Top Answer: 1
Timing chain tensioner is bad, I can almost guarantee it
Changed about 8 in the past few months, all made clicking sound like you described.
Old Jun 12, 2005 | 09:49 AM
SIIK2NR's Avatar
Is this a "replacement" or an "adjustment" Billman? I thought I saw a write up on this..
Old Jun 12, 2005 | 09:55 AM
Billman250's Avatar
Top Answer: 1
Replacement. It's about 110-140 bucks, and goes in directly under the VTEC valve. Easy, DIY job
Old Jun 12, 2005 | 10:01 AM
SIIK2NR's Avatar
Old Jun 12, 2005 | 02:53 PM
PathNull's Avatar
So this is something I could do on my own, if thats the case? Any thoughts if this is having a detrimental effect on the car right now? I absolutely want to fix it, but finding the time is the problem.
Thanks for the help guys!
Old Jun 12, 2005 | 04:16 PM
oakfloor's Avatar
yup my 00' makes a sound like this. can anyone post a DIY pic post.. billman?
Old Jun 12, 2005 | 06:28 PM
Billman250's Avatar
Top Answer: 1
14510-PCX-005 is the tensioner assy part number. You can bet you'll get something different if you don't give them this number.
I will do a DIY post when I have a lil free time.
Old Jun 12, 2005 | 07:18 PM
PathNull's Avatar
Thanks Billman, it's appreciated
