help needed plz
Old Mar 12, 2007 | 09:37 AM
yosephs2k's Avatar
Default help needed plz
hey ppl,
since i got my car, at slow speeds or when i brake i have been hearing a faint grinding noise, kindof like when ur brakes go bad.. and a little squeaking when im driving real slow.. i went to the dealership and got my disks and pads changed for new ones cuz the car is new.. and after a week the noise is back again.. exactly the same. i think it might be the wheel bearings, what do u guys think?
btw i read this thing abt the s2ks' brakes abt crystalizing or something like breaking in the brake pads.. u guys think that has to do with the noise?
thanx in advance and appreciate any help.
p.s. sorry for posting this twice.
Old Mar 12, 2007 | 11:15 AM
TrackStar's Avatar
What year is the car?
Old Mar 12, 2007 | 12:08 PM
yosephs2k's Avatar
2006, oh and btw when i press in the brake pedal i feel grinding at my feet..
hope that helps..
Old Mar 12, 2007 | 12:31 PM
TrackStar's Avatar
I thought it might be a wheel bearing. Jack it up and see if their is any side to side play in the wheel. Also, make sure the brake rotor shield isn't rubbing- that happened to me before. Good luck
Old Mar 12, 2007 | 12:32 PM
iDomN8U's Avatar
does the grinding go away when you brake? try applying the e-brake while moving slowly to eliminate the rear brakes only.
Old Mar 12, 2007 | 12:46 PM
yosephs2k's Avatar
thanks for the feedback.. i'll try to apply the e brake first thing tommorow morning.
i did jack it up and theres nothing wrong with the sheilds theyre clean.
if i feel it at my foot doesnt that mean its the brake pads?
oh and the grinding gets a bit louder when i brake.
Old Mar 12, 2007 | 01:03 PM
TrackStar's Avatar
Jack up the rear and start the car. The wheels should move even though it is in neutral. If not, something is obstructing it.
Old Mar 12, 2007 | 01:10 PM
iDomN8U's Avatar
Could be your brakes are wearing into the rotor, happens all the time.
How new is the car and when did you get it?
Could take a week or 2 depending on how much you drive
Old Mar 12, 2007 | 01:18 PM
yosephs2k's Avatar
the car is new and i replaced the brake pads and disks (rotors)
still there..
Old Mar 12, 2007 | 02:36 PM
iDomN8U's Avatar
And it will be until the pad gets worked in a bit. When you first get brakes you need to take it easy for a while
