help needed plz
Old Mar 12, 2007 | 04:11 PM
yosephs2k's Avatar
thanx man.. kindof late right now... i used them ever since i got them i think..
so u think i should take the car to the dealership? check bearings or something? just in case?
Old Mar 12, 2007 | 04:57 PM
iDomN8U's Avatar
no, just dont go from 100 - 0 back to back
Old Mar 13, 2007 | 08:48 AM
yosephs2k's Avatar
noise is still there dude.. i 4got to mention that the noise gets a bit louder when i take U turns or apply brakes at U turns..
is there any1 out there who has experienced this?
btw when u buy new brakes are u supposed to go very easy on them for a couple of hundred miles?
Old Mar 13, 2007 | 09:49 AM
TrackStar's Avatar
Like 50-100 miles
Old Mar 13, 2007 | 09:51 AM
TrackStar's Avatar
Did u check the wheel bearings like I said??? S2ki helps those that help themselves . . .
Old Mar 13, 2007 | 12:22 PM
yosephs2k's Avatar
didnt get a chance to go to the dealership.. will do 2moro morning..
so if i dont take it easy for 50 to 100 miles on new brake pads, what happens?
sorry abt all those questions, i really appreciate the help.
Old Mar 13, 2007 | 12:31 PM
iDomN8U's Avatar
I think it's because the pad needs to create a uniform wear pattern in the rotor, this way it will wear in more evenly.
Could also be a safety procedure that you give yourself plenty of time to brake incase you hit a air bubble in the lines from the brake job.
Old Mar 13, 2007 | 12:32 PM
TrackStar's Avatar
I think you should jack up the car yourself. When the wheel is in the air put one hand on top of the tire and one on the bottom and see if the wheel is loose when you move top hand in, bottom hand out and vice versa to see if you can shake the wheel. This will tell you the condition of the wheel bearings. Hope that made sense.
Dealers normally hire the worst grade techs. Take it to an independent mechanic or try to learn yourself . Good luck
Old Mar 14, 2007 | 01:30 PM
gello2024's Avatar
what gear are u on?
j12
Jul 28, 2010 02:04 PM
roguegeek
Jan 12, 2010 12:37 PM
blu_s2k
Feb 3, 2008 06:57 AM
yosephs2k
Mar 19, 2007 06:59 PM
mwy23
Sep 12, 2004 10:39 AM
