help with oil and CEL code
Old Mar 17, 2010 | 06:52 PM
s2kluca's Avatar
Default help with oil and CEL code
So i know s2000's burn oil. My friend suggested i go for a heavier weight oil like 5w40 or 10w40. What do you guys recommend?
The cel says vtec failiure. and i have an apexi vafc2 controller, could that be related? thanks. any info helps
Old Mar 17, 2010 | 06:56 PM
hypforlife32's Avatar
what kind of oil are you running currentley? what weight and waht brand? i was running royal purple and burned that alot. and switched to castrol gtx regualr 10w 30. i barely burn oil now like very little.
Old Mar 17, 2010 | 06:57 PM
s2kluca's Avatar
mobil 1 10w30. I think? Im running mobil 1 oem specs.
Old Mar 17, 2010 | 08:50 PM
s2kluca's Avatar
Also, when the CEL comes on it wont let me rev over 6k rpm
I need help.
Old Mar 18, 2010 | 04:51 AM
MasterForce's Avatar
Go to autozone and have them pull the CEL code. if you dont then this forum cant help you.
Old Mar 18, 2010 | 08:40 AM
s2kluca's Avatar
The CEL code is Vtec faliure. I already checked the code.
Old Mar 20, 2010 | 02:42 PM
s2kluca's Avatar
anyone have any advice?
Old Mar 20, 2010 | 05:49 PM
dammitjim's Avatar
Don't use Mobil 1. Do stick with 10w30.
Old Mar 20, 2010 | 06:04 PM
s2kluca's Avatar
What should i use? Also thanks for your input
Old Mar 20, 2010 | 07:06 PM
dammitjim's Avatar
I like Redline 10w30
