HELP please
Old Aug 16, 2008 | 09:01 PM
s2ktimmy's Avatar
Default HELP please
Not sur eif this is in th eright spot
but i have something loose on my front right windshiled frame were the latch goes to it really loose and moves around and i think thta what making my hard top noise the left side is fine and does not move at all it on the inside of the frame ..
Old Aug 17, 2008 | 08:49 AM
s2ktimmy's Avatar
no one....
Old Aug 17, 2008 | 09:20 AM
negcamber's Avatar
Unfortunately...there aren't that many hardtops out there. So you may have to wait a bit for a hardtop owner who has had the same problem to find your post.
Otherwise, check the latches to see if they are rattling. Does the rattle happen when you are using the soft top too?
Old Aug 17, 2008 | 10:38 AM
s2ktimmy's Avatar
actual it on the front window frame it moves all around but the left side does not move at all/
Old Aug 17, 2008 | 02:26 PM
negcamber's Avatar
Take the hard top off for a week or so and let us know if it is still rattling with the soft top.
You might pull all the plastic covers around the windshield frame to see if there is anything loose in there.
Old Aug 17, 2008 | 05:43 PM
Avionics86's Avatar
You can get the hardtop strikers from hardtop guy or try putting a small piece of rubber between the latch and the striker to tighten things up. Hope this helps.
Old Aug 17, 2008 | 06:21 PM
s2ktimmy's Avatar
i fix it i took off th epanel and one screw was missing and i found it in there lol so it all good now thnaks agian guys
pontypridd
Aug 22, 2015 03:57 AM
trustafox
Apr 23, 2012 10:25 PM
FISH22
Oct 10, 2010 05:17 PM
Jamil
Oct 5, 2010 09:06 AM
NAP1
Oct 11, 2004 10:57 AM
