Help Please S2k Start
Old Aug 16, 2015 | 06:58 PM
AlecsS2k's Avatar
Default Help Please S2k Start
Hi fellow s2kers
I went to start my car this morning and it would not turn on i found a youtube video of exactly what my car does if anyone knows how to fix this please help me thanks
Here is the video -----https://www.youtube.com/watch?v=OcT3L-UaFrw&feature=youtu.be
Old Aug 17, 2015 | 05:06 AM
windhund116's Avatar
What's the status of the starter wiring, battery, starter solenoid, and starter itself? You have any corrosion or loose connections in the large gauge wires and grounding points, under the hood?
Old Aug 17, 2015 | 05:38 AM
AlecsS2k's Avatar
Thanks for taking the time to reply but I really don't know much about any of those things and where to check it I'm nervous of messing around under the hood as I don't really know much about mechanical stuff
Old Aug 17, 2015 | 06:13 AM
blueosprey90's Avatar
Did you leave a door or trunk open overnight?
Is the battery more than seven years old?
Well, the first thing to do is to check your battery. It's in front of the passenger along the fender. It has a positive (+) and a negative (-) cable. One should be red the other black and the case of the battery should clearly show a + (positive) or a - (negative) at the posts.
There is a strap holding down the battery with two 10mm or 12mm nuts.
If you can get some jumper cables, hook up + to + and - to - and see if that will start the car. Hook up the positives first, then the negatives. Make sure the connections are good.
Otherwise, take out the battery and take to autozone to have tested.
You could also borrow a multimeter (perhaps at the autozone as they lend tools) to test the voltage at the battery. It should show about 13 volts at full charge. Car probably won't start at less than 9.5 volts.
Old Aug 17, 2015 | 06:44 AM
AlecsS2k's Avatar
Thanks for the reply I will check that out and see if it's the battery
Old Aug 21, 2015 | 11:52 AM
AlecsS2k's Avatar
Alright thanks everyone for the help when i used the jumper cables the car started so ill be going to oreilly auto parts and buying the "super start' car batteries
blink962
Sep 29, 2018 06:35 AM
blink962
Sep 24, 2018 01:32 PM
allstar71
May 11, 2013 11:16 AM
omil2374
Nov 18, 2008 10:03 AM
RYBA34
Jan 16, 2007 06:10 PM
