Help shiffork question?!
Old Aug 29, 2015 | 07:38 AM
Lionfighter's Avatar
Default Help shiffork question?!
Hey guys have a question. Is the shift fork(the part that end of slave cylinder pushes on) spring loaded? Does a part of the clutch give it then sping tension on ot? All of a sudden clutch peddle would not push down got home jacked up the car the slave cylinder rod was all sideways grabbed the rod came right out. I pushed on the shift fork got to move with hand no tension on it. So does the clutch need replaced or just the slave cylinder.
Old Aug 29, 2015 | 01:34 PM
afzan's Avatar
the "spring" is the pressure plate
Old Aug 29, 2015 | 02:55 PM
Ok that's what I thought thank you so much!! The clutch must have a total failure!!
Old Aug 29, 2015 | 02:58 PM
What part of the clutch assembly gives the pressure plate it's spring tension?
Old Aug 29, 2015 | 03:01 PM
Slowcrash_101's Avatar
Fingers.
rpg51
Oct 26, 2018 03:22 PM
rikhemi
Oct 9, 2010 03:41 AM
vwpiloto
Mar 22, 2009 12:15 PM
Ron
Jun 2, 2007 01:23 PM
MQS
Nov 15, 2006 06:20 PM
