HELP-stripped timing gear bolt
Old Jun 7, 2008 | 10:10 AM
fatjoe10's Avatar
Default HELP-stripped timing gear bolt
Well, my 3mm headgasket finally went. I was in the process of removing the timing gear, and the bolt that holds it got stripped. It is not completely rounded off, as I backed off and haven't touched it since, but it is definitely starting to strip. Given that it is in such a sensitive place (or so I assume), I kindly ask for your imput. What's the best way to get it out, out of many options? Thanks
Picture taken before damage.
Old Jun 7, 2008 | 10:36 AM
HankookS2K's Avatar
tap and use a reverse drill bit to get it out i suppose.
how did it strip? were you using the incorrect size allen? correct allen is a metric 8 allen.
ur definately gonna want to get a new one
Old Jun 7, 2008 | 10:56 AM
fatjoe10's Avatar
yes, I had an 8mm allen socket. It was very tight, so I put an extension bar on the ratchet, and that's when it stripped. I supposed I had to use a quick jerk motion as opposed to a gradual torque increase
Old Jun 7, 2008 | 11:05 AM
HankookS2K's Avatar
yea a quick snap is what u want to do.
at this point i mean your probably gonna have to buy a new bolt and get that bolt extracted so you might as well give it a go one more time with a quick snap to break the bolt free
unless someone else can chime in with another solution. last time i stripped an allen head i had to extract it with a drill
Old Jun 7, 2008 | 01:32 PM
SgtB's Avatar
Get an Easy out from the parts store. It will bite really well in an allen bolt.
Old Jun 7, 2008 | 01:48 PM
s2kattack's Avatar
easy out is probably the best way to remove it.
i have an extra bolt when you get that far.
Old Jun 7, 2008 | 06:18 PM
chino101's Avatar
Had this happen to a rusted allen screw on BMW rear breaks. We grabbed a inch allen key and pounded it in and cracked it loose. But the closest that you'll find to a 8mm is 3/8; might be too big.
Then again it might be a sensitive location, I'm not sure if I would be pounding anything on to a cylinder head.
Shaney
Mar 10, 2016 09:35 AM
91crxSi
Apr 9, 2015 08:02 PM
black2000
Apr 12, 2010 09:22 PM
ChefJ
Aug 15, 2007 07:17 PM
mayhan1980
Nov 26, 2003 08:47 AM
