Replacing O-ring for idler gear collar bolt
Old Apr 8, 2015 | 07:47 PM
91crxSi's Avatar
Default Replacing O-ring for idler gear collar bolt
So, I have a leak on the head of my motor from the bolt for the idler gear. I bought an o-ring (#23), washer (#22), and bolt (#9), as shown below.
See, http://www.hondaautomotiveparts.com/...FT+-+CAM+CHAIN
What do I need to do to replace these parts? Can I just remove the timing chain tensioner (after setting the cylinder 1 at TDC), and just loosen and remove the bolt? Or, will everything fall apart catastrophically, meaning that I have to take apart the cams and everything else first to get the job done?
Thanks
Old Apr 8, 2015 | 07:58 PM
titus69's Avatar
https://www.s2ki.com/s2000/topic/648...ont-of-engine/
Old Apr 8, 2015 | 09:16 PM
Gotpepsi's Avatar
^ great link.
In short, do not remove the bolt.
1. Loosen the bolt enough to expose the o-ring.
2. Cut the o-ring off.
3. Clean the area with carb cleaner.
4. Replace the o-ring.
5. Tighten the bolt to the correct torque.
Old Apr 9, 2015 | 03:04 AM
Slowcrash_101's Avatar
Just wipe clean, you don't want to spray something that dissolves oil getting in the engine.
Old Apr 9, 2015 | 04:08 AM
Back S2k's Avatar
^ not enough is going to get in there to have adverse affects.
op don't be scared of carb cleaner on this job.
Old Apr 9, 2015 | 06:09 AM
Car Analogy's Avatar
Right, I mean the bolt is still in place. How much carb cleaner is going to get past the threads into the motor?
Old Apr 9, 2015 | 07:04 AM
If fluids can leak out, they can leak in. Plus carb cleaner isn't good for rubber seals.
Old Apr 9, 2015 | 08:35 AM
Jdrum1's Avatar
Replaced the o-ring on mine a few weeks ago.......5 minutes tops.
Be sure to follow torque specs; you don't want that bolt backing out!!!!
Old Apr 9, 2015 | 09:44 AM
Jdrum1's Avatar
And don't back the bolt out too far.
I thought the o-ring would be more visible, and kept backing backing to bolt out. Thankfully, I realized it was right in front of me before I had loosened it too far! I then cut the old ring (which had lost all elasticity), wiped the channel off, and popped the now one in place. Torque, and done!
Old Apr 9, 2015 | 08:02 PM
91crxSi's Avatar
Thanks everyone. I really appreciate it.
Shaney
Mar 10, 2016 09:35 AM
Sabre
Jul 28, 2011 01:33 PM
sharptech
Dec 27, 2007 04:37 PM
Brian@Partshelper.com
Dec 17, 2006 12:11 PM
