HELP! weird light problem
Old Feb 21, 2016 | 09:19 AM
Hs2ktc's Avatar
Default HELP! weird light problem
ok so heres the situation.... so my brake lights are acting funny... when i turn on the lights on the car the tail lights work. but when i step on the brake only the right hand brake light comes on the 3rd light and the left hand stay off..... i dont think it is a fuse because one light comes on.. and the 3rd brake light is brand spanking new... so its not the bulbs. any other suggestions?
Old Feb 21, 2016 | 09:33 AM
kpro22's Avatar
Double check your fuse
Old Feb 21, 2016 | 09:53 AM
Hs2ktc's Avatar
but if the right brake light works would it still be a fuse?
Old Feb 21, 2016 | 02:32 PM
windhund116's Avatar
Did you double check the connections? Any breaks in the wiring?
Old Feb 21, 2016 | 04:33 PM
Hs2ktc's Avatar
double checked the connections and the wiring.... its odd because the right brake light will work 50% of the time but the left and the 3rd wont work at all. I replaced all the 10A fuses under the hood and under the dash... all the other lights work. i am wondering if it could be a brake light switch....
Old Feb 22, 2016 | 05:51 AM
Hs2ktc's Avatar
finally fixed it was a stop light switch.....
Old Feb 22, 2016 | 05:55 AM
Cool! Was this the switch on the brake pedal assembly? Did you need a new one? Or fix the old one?
Thanks!
Old Feb 22, 2016 | 06:29 AM
Hs2ktc's Avatar
yep it was the switch on the brake assembly i didn't have time to try to mess with it so i just replaced it. 25$ at orileys
what was throwing me off is that the third brake light still wasn't turning on but then it was a brand new led light
so i went back to another led light which didn't work... so i put the stock back on which did.. this was what was throwing me off...
it seemed to be a combination of a 2 bad third brake lights and a bad brake light switch but its all good to go now!
rsStewie
Apr 29, 2016 03:07 AM
Hs2ktc
Feb 21, 2016 01:51 PM
Coldfuse
Jun 30, 2014 04:58 AM
Devon85
Jun 22, 2013 03:16 AM
SmokingTSX
Jan 18, 2012 11:23 PM
