HELP! whining noise
HELP! whining noise
so, i took my '02 s2000 to a honda/acura specialty shop and they said i need a new tranny. i'll give a description and see what you guys think. i've had the car for 5 thousand miles, i'm at 84,000 right now, it's just now due for a fluid change, and that's when all this started.
the car is in neutral sitting still i rev with the clutch out, whining noise (on a loudness scale of one to ten, i'd say a five)
the car is in neutral sitting still, clutch depressed, no noise and smoother rev.
driving aggressive to driving conservitive there is no change, no slipping, no grinding, a lot of down shift compression slowing noise, but no tell-tell signs of tranny problems.
some one help, i hope somone can pinpoint this. thanks
another thing to add, the clutch is aftermarket, not sure what it is, but it's stiff as hell.
wow, ok... so i thought i looked good before posting a repeat topic, but after further review i found that a lot of people have this problem, my clutch does the exact same thing as "revs" does in his clutch post, like one down from mine. i've had lots of cars with aftermarket clutches, and i just assumed i had one, maybe not after reading his post.
dumbkid Posted on Oct 10 2007, 03:51 PM
This is no clutch buzz.
In this case only the primairy shaft is spinning, and the gears on the countershaft and primairy shaft.
The countershaft itself and sec. reduction don't spin during this, the diff and propshaft don't spin either.
Typical clutch buzz is driving in 3rd @ 4000 rpm, let go of the throttle and decellerate, then you will hear a buzz from the gearbox, about where the clutch is.
Its technically harmless, just vibration or noise caused by loose springs in the clutch disk.
In your case:
Ask in a local forum if there is a meeting you can go to and have someone else listen to your gearbox, to compare.
Your noise may be normal, it may not be.
Noises are hard to diagnose over the net.
When was the trans oil changed last time?
In your case:
tranny oil was changed two days ago after the problem (or not) presented it's self. i took it to the dealer and had them listen, i actually went to the back and pointed the noise out to them, they said it drove fine, and sounded fine to them. this noise happens when the the clutch is NOT engaged, then it goes away when clutch is engaged, also, it is louder at the 2500 to 3000 rpm mark. all this while sitting still, the noise is not as noticable during driving, it actually get's smoother in the higher rpm range, 6 to 9000. no gear slipage, no grinding, no tell-tell tranny problems at all, just the noise.
thanks for the reply
one thing to add, it's cooler in georgia now, after several days this summer of 100+ degree weather it's in the 60's as a low and 70's as a high, my point, the noise is less in the cold than the hot
If, on the other hand, you have a stock clutch then it should NOT be stiff, it should be wimpy as hell, which means you DO have a clutch problem. I suggest finding some local S2000 owners and compare pedal feel in addition to the noise. You may find some owners that have after-market clutches and you can experience what they feel like too.
The good news is that if you decide to pull the tranny for repair you will be able to check out the clutch before doing transmission job.
