HID Projection Issue
Old Sep 15, 2006 | 06:03 AM
MULDER's Avatar
Default HID Projection Issue
OK...
If you weren't aware I was recently in a fender bender. I recieved my car back yesterday from the body shop. They replaced my driver side headlight casing but not the ballast; they just used the old oneon the new headlight. Last night I drove it and noticed something terribly wrong... the diffusion of light from that side is horrid. There are three mail beams of light soming from it; one that is like a spot light and goes straight ahead but slightly tothe left, one that shoots left, and one that shoots right. Also, aside from the 3 beams of light, it is also flooding the road right infront of the headlight. What in the would did these duffus' do to it and how do I correct it? I have included a pic from my phone so that you can see.
Also. the HID beam on the driver side is bouncing with every little bump in the road I hit, unlike the pass side. The headlight itself is on and is not budging, I think it is the internals. What do I need to do?
This was taken standing directly in the center behind my car looking over the top:
THis was takin standing next the the driver door....
xvip??...
Old Sep 15, 2006 | 06:20 AM
Scott Evil's Avatar
Looks like the bulb is not completed seated. There is a small notch which must be lined up for it to correctly fit. The bouncyness may also indicate a loose bulb.
Old Sep 15, 2006 | 06:29 AM
Stratocaster's Avatar
I am going to agreee with Scott. The bulb will fit poorly if not installed right. It is keyed.
Old Sep 15, 2006 | 06:34 AM
MULDER's Avatar
How do I need to go about fixing it? Is that also the cause for the sporadic diffusion of light?
Old Sep 15, 2006 | 06:45 AM
You will have to pull the bumper off and remove the headlight. Rick's has instructions posted on our web site on how to do this. Also if you look at the Clear diffuser installation, it covers this part. The Clear diffusers shipping doc, covers the bulb removal and installation.
The bulb bouncing very well could do this. The light source is bouncing behind the lens so the output you see will change. Make sence?
Old Sep 15, 2006 | 07:03 AM
s2kshift9k's Avatar
^i agree with Stratocaster also
you have to make sure the HID bulb goes and clicks back in
i jus replaced im HID bulb 2 weeks ago
and yes there is a special key tool u need to take off the cover for the HID bulb.
Old Sep 15, 2006 | 07:07 AM
Originally Posted by JanNov s2k,Sep 15 2006, 10:03 AM
There is a special key tool u need to take off the cover for the HID bulb.
You can use a set of pliers to remove this. It is a Security Torx bit. The one with a hole in the center. Any automotive stores has them, but I always use a set of pliers.
Old Sep 15, 2006 | 07:29 AM
MULDER's Avatar
Argh. I just took that thing off last night to clear it...... I wish I would have known it was like this, I could have killed 2 birds with one stone...
Old Sep 15, 2006 | 08:08 AM
Sorry, if we would have know sooner we could have told you
Old Sep 15, 2006 | 08:13 AM
s2kshift9k's Avatar
o i didnt know that well since i work at a BMW dealership i got to come in on a saturday and work on my car so using the rack and the techs tools was cool but ya i first i thought i was screwed when i rean into that special lock thing
