HID'S
Old Oct 19, 2008 | 10:00 PM
skaterboyroland's Avatar
Unhappy HID'S
i just recently got my ap1 about two weeks ago. and i noticed today driving home at night, that when im on a flat road with my low beams on only, that they dont shine more than the width of two lanes. is this normal? when im driving over a hill, they shine so far away. im just wondering if its supposed to only shine that far? it annoys me because i cant see very far ahead of me, so i always have my high beams on.
Old Oct 19, 2008 | 10:40 PM
03supers2k's Avatar
Your beams are probably angled down
Check out the link it tells you how to fix it
Adjusting Headlights
Old Oct 20, 2008 | 06:27 AM
SgtB's Avatar
They may be adjusted wrong but realize that hids aren't like halogens. The cutoff is there to prevent you from blinding other cars. If it is that short though, you may need adjustment.
Old Oct 24, 2008 | 06:53 PM
ssthrd's Avatar
Are the lights on an ap2 adjustable as well? I've heard not........
I also have a very limited forward visual range with my hids to the point where i get a bit nervous going faster on a hilly road cause i can't see.
Old Oct 25, 2008 | 08:03 PM
g352s2k's Avatar
...........its normal and its called a "cut-off line". you can see the cut off line when your driving and it doesn't pass that cut-off.....unless you have HID fogs too!
Old Oct 25, 2008 | 09:46 PM
hariku821's Avatar
How come one is slightly higher than the other.. kinda bothers me that they arent even.
Old Oct 25, 2008 | 10:02 PM
cougar hunter's Avatar
its higher on the pass. side because you arent facing drivers on that side, so there is not a big chance of blinding an oncoming driver (if so youre drunk and on the wrong side of the road)...but really its lower in the drivers side because thats where other drivers are coming from obviously...
Old Oct 26, 2008 | 06:13 AM
Slows2k's Avatar
You bother to read the link? https://www.s2ki.com/forums/index.php?showt...0&#entry6845328
Old Nov 1, 2008 | 08:11 PM
ssthrd's Avatar
Tks Slows2k. I finally got my lights higher than the pavement 50 feet ahead of me.......... By the way, turning the adjuster clockwise raises the beam, and you have to use a #2 phillips screwdriver with an 8" shank.
Old Nov 2, 2008 | 07:22 PM
ssthrd's Avatar
So.....I have solved one problem thanks to this site, and it has lead to another.
After adjusting my lights, I parked in front of a wall tonight to have a look at the cutoff lines. I wanted to compare the overlap from left and right sides, so I blocked the light from the drivers side, and discovered that the passengers side is much dimmer than the drivers side, although it is still very bright.
I presume that both sides use the same light, so this doesn't make a whole lot of sense to me. Anyone have any ideas?
NineBolts
Jan 3, 2008 11:25 AM
s2gZ
Nov 5, 2007 08:20 PM
Paul(UK)
Jan 29, 2003 03:57 AM
bguernsey
Jul 27, 2001 12:57 AM
y2ks2k
Dec 26, 2000 05:10 PM
