High Flow Cat?
Old Jul 16, 2001 | 12:02 PM
Jeff's Avatar
Looking for a good quality high flow cat for the S2K. Don't want a straight pipe. Want an honest high flow bolt up. Anyone....Anyone! I've not seen much dicussion on this one. Expected gains or not?
Old Jul 16, 2001 | 12:31 PM
turbo_pwr's Avatar
there's tons of companies that make bolt on high flow cats. http://www.randomtechnology.com for example. All you would need is to supply them with the diamater of the pipe on both ends. I really wouldn't expect much HP gain if any, but worth a shot if you have the cash lying around I guess. Remember it is illegal to replace a non-defective cat, of course there are some many ways around that as well.
Old Jul 16, 2001 | 03:17 PM
vtecvoodoo's Avatar
I`d just hollow out your stocker. I`m not a big "high flow" cat fan.
Ryan
Old Jul 16, 2001 | 03:20 PM
joe_s2k's Avatar
I believe 1RandyC put in a high-flow cat with marginal results. There wasn't much of a gain, if any.
Old Jul 16, 2001 | 04:51 PM
mav's Avatar
mav
I wouldn't do it... Your car will be signifcantly louder, you could experience sensor problems (which Honda will not fix since you modified your cat), and the gains are none.
I did it to my old '96 Eclipse GST... I got a much louder car, had three sensor malfunctions (I paid 100 each time to fix), and didn't experience any performance gains.
Old Jul 16, 2001 | 05:35 PM
Takashi KazuMori's Avatar
I second the opinion to hollow the cat out ... No point getting a high-flow cat when it's gonna be just as noisy, probably less environmental damage and definitely improves acceleration. Makes no difference to the law-enforcement type anyway.
Old Jul 16, 2001 | 08:57 PM
Silver Bullet's Avatar
Ryan
When you say "hollow out" the stock cat, do you mean remove the material inside? I read the advice of somebody on a different forum at one time that said to take a coat hanger and bust up the catalyst material inside. Is that what you meant?
I don't see how the car could pass an emission test in California if you do that. I can also see sensor problems and out-of-warranty problems.
Old Jul 17, 2001 | 08:59 PM
TurboVtk's Avatar
simple, get a spare cat and you can use it for inspection time, swapping a cat is less than a 10 min thing, and if you have it in the area most owners can rent it from you to do their emmisions then get it back on,its a do it your self job no really hard thing to do, had it on my 96 gs teg.
Old Jul 18, 2001 | 01:17 PM
BigWave10's Avatar
Most cats on vehicles made over the last 5-10 years are already considered "high-flow" unlike cats of the past.
If you can sucessfully do away with it for a "race application" fine.... if not, it's usually better to leave them alone.
Atr-platti
May 18, 2018 04:22 AM
rossco
Mar 11, 2016 12:53 PM
d21x
Dec 24, 2014 10:01 PM
MUAY_THAIerd
Feb 18, 2008 04:17 PM
mikecl713
Sep 20, 2003 08:31 AM
