high pitched sound from engine
Old Mar 6, 2009 | 07:35 AM
SCCS2K's Avatar
Default high pitched sound from engine
(FYI - changed thread title from "intake whistle question")
hi again...
so about a week ago, i started noticing a rather loud high-pitched whining/whistle coming from the engine, about the same frequency as squealing brake pads. it happens ONLY at idle. the moment i rev the car or pull on the cable, it disappears. i've never heard it while in gear.
anyway, so this sounds like the standard "s2000 intake whistle", yes? i can't think of what else it could be.
the reason i'm asking about it is - i have a stock intake, brand new filter. nothing changed a week ago, however, i replaced the IAC about a month ago.
could the new IAC be the cause of the whistle? i noticed it's a slightly different unit (gold-colored now, instead of silver). if so, is this still ok and no cause for worry, or is there anything i should check out?
if it's not related to the IAC, is it normal that the whistle would appear randomly like this?
thanks, as always.
Old Mar 6, 2009 | 09:15 AM
shotiable's Avatar
thats weird... i never noticed a whistle sound when i had my stock intake, but its quite frequent with my kn kit
Old Mar 6, 2009 | 09:19 AM
9000Addiction's Avatar
Not talking about the whistle that comes from the air pump are you?
Old Mar 6, 2009 | 09:47 AM
SCCS2K's Avatar
maybe? can you explain more?
Old Mar 6, 2009 | 09:56 AM
Atleast for AP1 not sure about AP2. we have an Airpump for smog purposes that feeds directly into the intake elbow. you can find a large hose connected to the right side. Normally you will hear the whistle a few seconds after you first start the engine and it should run for about a good minute or so. I hear mine every single morning. It's a normal whining/whistling sound.
SCCS2K's Avatar
oh one thing - i did run a bottle of techron through about 2 weeks ago. can't imagine that would matter though.
i'm saying that just in case the whistle has nothing to do with the intake/tb after all.
Old Mar 6, 2009 | 09:57 AM
SCCS2K's Avatar
oh, right... no, it's not that.
ps - it is an ap1.
Old Mar 6, 2009 | 10:00 AM
If you pour chevron gas dont even bother with buying techron bottles...
If you arent pouring chevron gas and decide to you a bottle of techron you need to use it for roughly 1000miles for the effectiveness of the detergents to work.
Old Mar 6, 2009 | 10:07 AM
SCCS2K's Avatar
(i do use chevron anyway. it still needed a bottle of techron, separate issue.)
i just listened to it again. i can't necessarily place the sound to the intake/tb, it's just seems like it's emanating from the engine in general. a loud, super high-pitched "beeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeee" (lol), only when idling.
but in researching here, it sounds like what most people are calling the "intake whistle".
Old Mar 6, 2009 | 10:10 AM
Stock intake airbox?
