Hit Rev Limiter - Strange things happening
Hit the rev limiter on a mis shift last fall on a KW kitted 06. Since then car runs fine at lower (<4000) rpm but when it comes up to VTEC it spits and sputters and the AFR goes rich, like 10:1 and showing some knock in #2. Pulled plugs and they looked a little fouled so replaced them which helped but still not wanting to rev past 4k. Replaced the coil on #2 and that got rid of the knock but still wont go past 4k. Car has under 59k miles on it, so going to adjust valves next. I cant imagine the valve train took any damage as it runs fine at the lower RPM. Next logical step I guess is the VTEC solenoid. Anyone have any thoughts?
Rob
Rob
Spark blow out? what are the plugs gapped to? This is not uncommon, however usually this tends to happen a bit higher in the rpm range where fuel duty is higher putting more demands on spark. If the gap is too big, the spark will get flooded. Ambient temp and 02 feedback will change fuel demands and cause break up if was close to threshold previously. Generally a good plug gap for a 400whp supercharged set up is about 0.22-25.
Corey at Slowmotion did the tune. It was a misshift. Hit 3rd from 4th instead of 5th but not at a real high RPM. I just cant believe it would run as smooth as it does under 4k RPM if it was a valve but will get it checked out.
