Hole in Intake Tube / Pipe
Old Aug 21, 2014 | 11:35 AM
kevinS2OOO's Avatar
Default Hole in Intake Tube / Pipe
Hello,
I did a research but couldn't find a solution...
So I tried to install it this afternoon and near the end of the installation I have a question. Since I bought it used, the previous owner inserted a hole here with a grommet (part AB on the instruction PDF), well it is a hole. I pulled out the grommet already and now just brainstorming a solution.
How should I fix it? Heat wrap tape?
Thanks everyone!
Kevin
EDITED: I was thinking about wrapping that specific section with this:
http://www.oreillyauto.com/site/c/de...+ties+%26+clam
Old Aug 21, 2014 | 12:20 PM
mugen_rsx09's Avatar
After you wrap it put a nice sticker on it
Old Aug 21, 2014 | 01:04 PM
_brandon's Avatar
buy a rubber plug? haha
Old Aug 21, 2014 | 03:19 PM
slowd16's Avatar
I had a PRM that the previos owner drilled for nitrous so I just wrapped the whole thing in gold tape. Never had an issue with it.
Old Aug 21, 2014 | 09:36 PM
lleron's Avatar
Is that from an 06+? It looks like an IAT port to me.
Any hardware store (or even HD/Lowes) should have a good selection of solid rubber stoppers you can just stick in there. You could probably even put in a short bolt that fits tightly in the rubber grommet with no problems, as it only sees vacuum.
Old Aug 22, 2014 | 09:20 AM
kevinS2OOO's Avatar
Yeah it came off of an 06+ S2000. I decided to tape it with heat resistant tape that is normally used to wrap around broken exhaust...supposed to be pretty air tight.
Here is another problem. When coming to a stop, I have rough idle issues. It stalled several times but when I restarted the engine it was back to normal...I don't know if it was caused by the air filter I cleaned (using K&N air charger kit) or the hole.
Any pointers would be much much appreciated. Thanks!
Old Aug 22, 2014 | 03:23 PM
Chuck S's Avatar
The 2.2 engine needs an inlet air temperature sensor and that's where the former owner decided to put it.
-- Chuck
Old Aug 22, 2014 | 04:47 PM
rrounds's Avatar
I would and did put a air filter restriction gauge in that hole.
http://www.amazon.com/Wix-24801-Air-.../dp/B0014BI1KA
ROD
Old Aug 22, 2014 | 05:47 PM
kevinS2OOO's Avatar
ROD
Hmm, this actually sounds like a great idea. I will look into that! Thanks.
Old Aug 22, 2014 | 07:04 PM
Slows2k's Avatar
-- Chuck
All S2000's have intake air temp sensors. In 2006 the sensor moved to the intake tube. From 2000 to 2005 the sensor is attached to the intake manifold.
