Hole in K&N intake
Old Jul 19, 2006 | 06:24 AM
myclue's Avatar
Gold Member
Default Hole in K&N intake
Hey guys! i just installed the K&N Aircharger on my 06 S2000.... and wow do i love it. Everything sounds just so great in VTEC. However, as you know, the 06 intake requires some drilling. After putting the grommet that k&n provides into the irregular hole that i drilled ( i didnt have the exact 5/8" inch bit, so i drilled about 6 1/10 inch holes together ), there is a little hole that is coming out of the grommet from the intake. I am thinking about using some sealant on the hole. Everything runs fine though. Anyone have any input on how bad this hole is? it is actually very very small, about hald a millimeter. How well will the sealant work? Any input will be appreciated thanks guy!
Old Jul 19, 2006 | 08:17 AM
NFRS2kSi's Avatar
a small amount of dust or dirt would go in thru the hole. just weld that sucker up.
or tape it up hehehe
Old Jul 20, 2006 | 01:13 PM
vtec9's Avatar
silicone caulk that sucker
Old Jul 21, 2006 | 08:04 AM
myclue's Avatar
Gold Member
yep, got some high temp silicon sealant. thanks guys!
Old Jul 21, 2006 | 08:13 AM
Dark's Avatar
I can see sealant getting sucked in. I would recommend a piece of color-matched tape (or a similar color).
Old Jul 21, 2006 | 08:21 AM
CIVICTOS2000's Avatar
Old Jul 21, 2006 | 09:03 AM
vtec9's Avatar
uh through a hole of less than a mm I doubt it.
Old Jul 21, 2006 | 09:55 AM
jzz30's Avatar
if in doubt use some 5 min. jb weld!
User 111717
May 16, 2012 10:00 AM
trAP2
Dec 14, 2011 09:35 PM
jid1987325
Sep 30, 2009 10:50 PM
geoff2005
May 17, 2007 04:35 PM
