At home compression test?
Old Jun 24, 2007 | 06:51 PM
ChefJ's Avatar
Default At home compression test?
What do I need to do besides purchase the compression tester to test it at home?? What fuse or harness is disconnected so that the engine only cranks and doesn't fire?? I did a search but couldn't find anyhting and I would rather do it myself then take it to a dealer.
Old Jun 24, 2007 | 06:55 PM
BlownAP's Avatar
no spark plugs = no fire
Old Jun 24, 2007 | 06:58 PM
ChefJ's Avatar
so what you are saying is pull all of the spark plugs first?? or just disconnect the harnesses
Old Jun 24, 2007 | 07:27 PM
sahtt's Avatar
It's very simple. BlownAP's comment doesn't help you much.
First, buy a screw in or thread in type [same thing] compression tester. They can be found at autozone usually.
If you want, you can pull the fuse to the fuel pump. I usually do not but if it makes you feel better do it.
You remove all the spark plugs. You install the compression tester similar to installing a sparkplug. You then crank the ignition with the motor WARM, NOT* hot, at WOT; for best results.
You keep the ignition turned until the gauge no longer increases noticeably. Usually it's just a matter of seconds. Do the same for each cylinder [each spark plug hole].
A leak down test is also a vital tool you should look in to.
Old Jun 24, 2007 | 07:32 PM
ChefJ's Avatar
Is this something I can do by myself?? I mean will the gauge needle hold the pressure reading until I can get out of the car and read it? Or will I need to crank the car over and have someone read the tester??
Old Jun 24, 2007 | 11:39 PM
iam7head's Avatar
[QUOTE=ChefJ,Jun 24 2007, 07:32 PM] Is this something I can do by myself??
Old Jun 27, 2007 | 04:50 PM
fadiss2k's Avatar
Here is a link for a DIY that i made a while back, but was never stickied.
DIY COMPRESSION TEST
Fadi
Old Jun 27, 2007 | 05:00 PM
iam7head's Avatar
Fadi
not to be rude but you cranking it by the number of crank is better than cranking it counting by time.
plus the human error factor of 4-5 seconds will varies alot.
Old Jun 28, 2007 | 09:52 AM
fadiss2k's Avatar
Not taking it in a bad way at all! Fixed it! Thanks...you have a good point!
Thanks
Fadi
Old Jun 28, 2007 | 11:32 AM
ChefJ's Avatar
Thanks again guys.
Bruunz
Aug 5, 2018 04:08 PM
S2000Fodder
Feb 26, 2011 07:11 AM
Sargeant Handbag
Mar 4, 2008 12:45 PM
05S22
Aug 22, 2005 05:21 PM
Gymniac
Apr 20, 2003 02:59 PM
