Honda diagnostic tester
Old Feb 12, 2005 | 02:15 PM
heyne's Avatar
Default Honda diagnostic tester
Pgm testers(like used at a dealership) cost $2000+. I have seen diagnostic units on jegs or summit that cost about $200. My s2k, as everyone knows, is a salvage project. Can i use this tester in my favor to get codes and/or reset some of these codes?
I'm having problems with ABS, SRS, & a fuel gauge that doesnt read.
Anyone?
Old Feb 12, 2005 | 02:20 PM
Billman250's Avatar
Active Streak: 30 Days
Active Streak: 120 Days
Top Answer: 1
For 200 bucks, all it will do is read and define OBDII generic codes (P codes), and possibly display manufacturer specific codes with no definition. Not going to help you in your case.
Old Feb 12, 2005 | 02:46 PM
heyne's Avatar
Alright. Can you think of any thing that will help me?
Old Feb 12, 2005 | 08:51 PM
Slows2k's Avatar
No PGM or HDS tester is going to help you with the fuel gauge, it's not a supported item in the data stream.
The $200 OBDII code reader is only going to get you generic P codes and some of the freeze data.
The last time I priced a PGM tester it was closer to 5k, and the HDS runs around 7k.
Of course you have to be a dealer tech or a dealer to get either.
Chances are if the Airbags deployed, you'll have to replace the SRS unit, and any deployed bag or belt before the light will go out.
You can always take it to the Dealer to have the DTC's pulled.
This may be your only option.
jdrsxtypes
Jan 13, 2013 05:20 PM
GyozA
May 29, 2010 07:51 PM
civic si hb
Aug 31, 2008 04:38 PM
generalpatton
Aug 6, 2005 08:55 AM
sleepers2k
Apr 4, 2003 05:29 PM
