Hondata heatshield installed...
Old Feb 9, 2006 | 05:29 AM
24s2k7's Avatar
Default Hondata heatshield installed...
My Hondata heatsheild is installed on my car. But I am worried everything isn't tightened down well enough. For those of you who have done it, you know how hard it is to get to all the hidden bolts with a U-socket and tighten everything down. When I turn on my car what should I be looking for as far as if anything was done wrong or not tightened enough? What would be some indications of bolts not being tight enough?
Old Feb 9, 2006 | 06:36 AM
react's Avatar
if it falls off you know it's not tight enough... lol if you tightened 3/5 bolts correctly and 2 of them tight but not to spec you will be fine..
Old Feb 9, 2006 | 10:26 AM
KAIZENSPEEDReid's Avatar
Usually if the intake manifold isn't torqued properly there will be a vacuum leak which can cause the car to idle high or idle surge.
Old Feb 9, 2006 | 03:34 PM
spider2k's Avatar
Active Streak: 30 Days
and coolant leaking.
Old Feb 9, 2006 | 11:29 PM
S2oooNvegas's Avatar
dude, they MUST be retorqued after a day of driving. MUST. at 16 ft lbs. they are always almost 1/2 turn loose. trust me, retorque. lates
blixhavn
Aug 26, 2015 09:11 AM
jyeung528
22
Apr 10, 2008 03:38 PM
wildcardtrd
May 8, 2006 12:30 PM
fperra
Aug 10, 2003 01:16 PM
KYS2000
Nov 25, 2002 08:00 AM
