Hood prop/support too heavy
Tanqueray
I lost 30 lbs with my wheels and lugs, then used stock rubber.
for under 1600.00
then sell your stock wheels and you have reduced your cost to just over 1000.00
You need to check your options better.
for under 1600.00
Originally posted by Rick
when you remove rolling weight or turning weight it will almost equal double that amount in static weight.
Also, reduction in weight for rotating mass will not guarantee better performance. It is all about where the weight is.
What you are proposing to do is good, but they way you are proposing is not the cheapest by far.
http://shopping.oraclesmallbusiness.com/ap...c=7&category=48
The cheapest titanium bolt on the above site is $4.50. It would take about 153 M5 bolts (stnls to tit) to equal a pound of savings. That's a $686/lb. Not a very good deal.
Go for the big stuff first...battery, wheels, flywheel, exhaust, spare tire.
" Go for the big stuff first...battery, wheels, flywheel, exhaust, spare tire"
I thought that was well understood, I have done all that.
when you want to win every ounce counts! No one said it was going to be cheap.
Rick, are you serious?! You're one of the funniest members I've seen yet. Please don't take that to heart.
Anyways, your theories are a joke. Taking off the hood support to save weight?
-carbon fiber hood
-carbon fiber trunk lid
-remove trunk liner & spare
-remove jack & tools
-remove all heatshields
-remove owners manual & paperwork (paper's heavy!!!!!
-remove floormats
-remove stereo & speakers
-remove passenger seat
-remove sunvisors
-aluminum brake calipers
-cross drilled slotted lightweight rotors
-aluminum crank pulley
-aluminum flywheel
-carbon driveshaft
-gel-cell battery
-carbon fiber plug cover
-lightweight radiator supports
-carbon fiber intake
-titanium exhaust
-aluminum lightweight radiator
-5W-30 oil.. lightweight
-replace engine mounts with lightweight aluminum moutns
-all aluminum suspension
-manufacture aluminum control arms
need i go on?... come on.. this is a joke.. buy an intake and be happy with it.
-carbon fiber hood
)-remove floormats
-remove sunvisors
-aluminum flywheel
-carbon driveshaft
-gel-cell battery
-titanium exhaust
How about save the money and lose some body weight (nothing personal, directed at no one)......or take a big dump before going for a drive.
This way, you will get a 'lighter' car and be healthier.
