Horn honks when momo wheel is turned hard
Old Aug 11, 2012 | 08:28 PM
Glock19carrier's Avatar
Default Horn honks when momo wheel is turned hard
Hello I'm new and have an issue with my 02 ap1. When I turn hard left sometimes my horn will honk then stop as I keep turning back to straight. I have a momo wheel with NO quick release. Thanks for any help
Old Aug 11, 2012 | 08:37 PM
99SH's Avatar
Did you remove the horn button to see whether any contacts are touching structure ground?
Old Aug 11, 2012 | 08:45 PM
Do I just pry the horn button off with a screw driver. Sorry I got the car with the momo wheel and did not install it.
Old Aug 11, 2012 | 09:16 PM
99SH's Avatar
Remove the horn by either
1. Prying it out (it's pressed in lightly)
2. Remove the steering wheel
3. Slide the steering wheel hub boot down and pushing the horn button out from the back (you may not be able to do this depending on your boot & hub)
Old Aug 12, 2012 | 08:49 PM
I took the horn button off and did not see any issues. If I remove the 6 Allen bolt from the center of the wheel to take the wheel off will this set off any type of CEL, SRS light? Also is it fairly straight forward to take off the wheel and check the horn, b/c I did not install the wheel. It came on the car. I don't want to take the wheel off and not be able to reassemble it. Thanks
Old Aug 12, 2012 | 09:26 PM
99SH's Avatar
Yes, taking the wheel off is as simple as undoing the allen bolts. No you will not trip any SRS or CEL lights.
You can check the horn ring when you remove the wheel. It's a circular steel piece which sits between the wheel and the hub with a small tab protruding out. This provides reference ground for the horn.
Old Aug 13, 2012 | 05:38 AM
Ok thank you for the help!
Old Aug 13, 2012 | 10:54 AM
qczhao's Avatar
This post won't be of any use to you, but I just wanted to say that this is a pretty funny issue
bgoetz
Feb 17, 2015 07:33 PM
mobile chicane
Jun 13, 2011 09:01 AM
RobinA3
May 15, 2011 06:02 AM
S2Kyle01
Dec 8, 2007 07:23 PM
sctyboy
Sep 22, 2007 10:17 AM
