Hose Connector?
Ya that's a good idea for now. I was asking myself the same questions about just using 1 hose. I haven't had any of them replaced before so I'm curious as to why it was like this to begin.
There isnt one connector its 2 tubes. you remove that part when you install certain intakes.
seems like it was simply connected by a random piece of plastic by the previous owner. probably didnt have a hose long enough to connect it.
Hmmm.... Ya I understand the two tubes, but I'm the only owner of the car and I haven't done anything to that hose or had anything done to it either. Unless it was something that I replaced when I put in that Injen intake 8 years ago? Anyone else with a Injen intake have these same tubes?
Yes that Injen intake is probably the cause you got that plastic piece.
Now get a longer hose so you can bypass the throttle body and the intake air control valve, it will help your intake manifold run cooler.
