Hot start issues
Old Jul 1, 2017 | 06:39 PM
Halfassjack's Avatar
I had same issue. Was starter. Replaced it and no more trouble for ME. Expensive and not easiest job. Preform test I mentioned earlier as well as look at wave form pattern. Waveform pattern takes a scope. Not everyone has one. Volt drop test can be done with volt/ohm meter. Don't try amp test on starter without shunt or vat40 or something able to handle the high amp a starter requires.
Old Jul 1, 2017 | 08:45 PM
Charper732's Avatar
Do you know the amp draw spec? I haven't heard of someone refer to a shunt in years lol, right on
Old Jul 2, 2017 | 04:39 AM
flanders's Avatar
On cold start mine was drawing 460A peak, measured with Fluke scopemeter and current clamp.
I think nominal current is rated at 100A.
Old Jul 2, 2017 | 06:58 PM
Slowcrash_101's Avatar
You need at least 80 sustained amps @~12V to turn the car over, or just under .6kW of power any less and that starter is going to struggle. The alternator/generator outputs up to 105 amps.
Old Jul 6, 2017 | 01:29 PM
blink962's Avatar
for those that did the relocation,you wired starter directly to battery?
SimbaDogg
Jun 4, 2019 03:48 PM
blink962
May 15, 2015 05:25 AM
ChefJ
Nov 29, 2007 07:01 PM
darkwatch
Nov 19, 2007 08:00 AM
