How can I test the differential
Old Sep 26, 2003 | 11:03 PM
1FastS2k's Avatar
I'm having some concerns that my diff isn't working right. Are there any simple tests that I can do to check for myself before I take it in to the dealer?
Old Sep 26, 2003 | 11:50 PM
mikecl713's Avatar
jack the car's rear up turn one wheel and if the other wheel doesnt spin the opposite direction of the wheel u spinned then something is messed up
Old Sep 27, 2003 | 08:00 AM
xviper's Avatar
What kinds of concerns? What do you suspect is wrong? What Mike has described will only tell you if the LSD is OK.
Old Sep 27, 2003 | 08:17 AM
1FastS2k's Avatar
Well, I had the rear end jacked up double checking the bolts on my exhaust and I remembered that a friend had mentioned that test before.
So, I spun one wheel but the other one didn't move. When I spun the passenger side, nothing happend on the drivers. When I spun the drivers, the passenger moved about an inch then stoped. Any other suggestions? Do I have a bad diff. It's been a while since I changed the diff fluid. Could that be it?
Old Sep 27, 2003 | 10:24 AM
slalom44's Avatar
Top Answer: 1
Is it possible that you have the car in neutral? Put the car in gear and try again and tell us what happens.
Old Sep 27, 2003 | 11:17 AM
xviper's Avatar
The diff fluid should be changed annually on this car regardless of what the owner's manual says. This car's diff is a weak link and takes quite a beating.
Old Sep 28, 2003 | 01:50 AM
1FastS2k's Avatar
Now that I think about it, the car was in neutral. I ASSumed that the wheels wouldn't spin if the car was in gear.
wrightbenz
Aug 27, 2011 09:26 PM
rmk232
Jan 3, 2011 10:52 AM
FASTSIIK
Oct 12, 2008 06:16 AM
SilvCF2k
Oct 19, 2006 11:29 PM
spider
Jan 19, 2002 08:33 PM
