How to Clean IAC Valve
Old Nov 7, 2010 | 06:55 PM
  #71
SorakS2K's Avatar
I did a MAP Wack, clean my IAC and replaced new PCV on my03.. 108,000 miles....
Old Nov 8, 2010 | 10:05 AM
  #72
robodeath's Avatar
Originally Posted by robodeath,Nov 4 2010, 09:55 AM
I'm about to do this, I got a P1519 code
My MY01 is at 71k miles. Man it's idling rough and keeps throwing that code. I have got to find some time to do this.
Old Jan 19, 2011 | 11:42 AM
  #73
lucky666's Avatar
bump. pretty sure this is my problem. im throwing the code. here is a video i made because i couldnt figure out wtf the issue was because it wasnt throwing a cel at me till recently.[media]http://www.youtube.com/watch?v=VnRV3lsJabw [/media]
Old Jan 19, 2011 | 03:38 PM
  #74
lilsharky's Avatar
^^ sorry i loled to that. thought your car was singing at idle but good luck with your problem
Old Feb 9, 2011 | 04:44 PM
  #75
billiardboy904's Avatar
I too was having idle issues at stops for a couple weeks now. Recently, The car would die once the clutch was pressed. This prompted me to a solution which I found here. And what do you know, NegCamber, a JAX local and good friend of mine wrote this article. It worked for me. Hope it works for you all.
Don't forget to reset your ECU after performing the test. This didn't completely fix my issue until doing so.
Old Feb 9, 2011 | 06:16 PM
  #76
clio's Avatar
does coolant leak out when pulling this off?
Old Feb 9, 2011 | 06:47 PM
  #77
onions2k's Avatar
Minimal leaks out as alot of it should be in your radiator by then.
Old Feb 9, 2011 | 09:31 PM
  #78
TRD_Celica's Avatar
It would work for me for about a week then it just goes back to normal
Old Mar 14, 2011 | 02:19 PM
  #79
SpitfireS's Avatar
One observation:
The roller valve uses 2 small sealed roller bearings.
Usually, sealed bearings are greased for life.
If you use (a lot of) solvent to clean out the ICV you might also wash out the grease of the roller bearings.
I noticed the solvent running out one bearing, because I also removed the "motor".
You could drop a little oil on the inside of the ICV on the 2 bearings to give them some lube.
Btw.. removing the motor is not recommended.
First: you need a 5 point torx driver, I've never seen one.
I ended up cutting a groove in the bolt so I could use a flat screwdriver - I replaced the bolts with internal hex head M4's.
Second: the position of the motor is adjustable, and so is the position of the rotary valve.
So you need to make sure you put it back in the right position.
On the bright side, if your idle is still shaky you could change the position of the motor to see if it changes the idle behavior.
Old May 8, 2011 | 10:38 PM
  #80
Lovenpain's Avatar
Originally Posted by seth2k
my car does this sometimes randomly. maybe once every 15 stops. with the a/c on it's a different story entirely, the engine bogs on the verge of stalling. I also have to give it more juice on the get go from a stop or it bogs hard and almost stalls. need to try this IAC cleaning I guess. bad compressor maybe? a/c still blows cold but it drags on the engine way too hard. any suggestions?
Try replacing O2 sensor. I was old to try this as well cause my car is having the idling issues!
