How do i clean VTEC solenoid ?
I can't feel when my vtec crossover. So iam going to try to clean vtec solenoid but don't know how. The oil is good but it seem the vtec kicked when away when I switch over to mobile one synthetic oil. Is this the vtec Solenoid? This thing is corroded very bad? Should I replace it? sorry i cant edit pictures in my account
[img=http://img253.imageshack.us/img253/9613/utf8photo.th.jpg]
it's very rare for them to fail. Corrossion on the outside doesn't mean anything on those pieces, they will rust if exposed to moisture and salt.
Have you changed an intake or exhaust recently, that tends to smooth out the vtec kick. It happened on my car when I made ane exhaust change. A smooth vtec transition is usually a good sign.
To remove it, unplug the electrical connector and three bolts, there is a screen behind it. You can also take it apart as it is in two pieces and see if the interior plunger moves freely. Reinstall the bolts to 8 ft lbs upon installation. I doubt it's your issue though.
Originally Posted by s2000zr,Nov 27 2010, 07:20 PM
Everything is still stock. I like the vtec kicked even if smooth vtec is good for the engine. Do I remove the three top bolt or the side one? Thanks
