How do you reset the Steering EPS?
Old Apr 14, 2003 | 06:27 AM
AndyDoh's Avatar
Oh & thanks to Mas
I thought someone had stole your cornflakes!!!!
Andy
Old Apr 14, 2003 | 11:17 AM
swtazn97's Avatar
I don't remember if i noticed this but... When you turn the key to II. These lights should stay on: Brake, Battery, and Oil. Directly on the center is the EPS light. I am not sure if that was on before when i first got my car. Is that normally there to stay on when you turn the key? Does this mean that i have to reset that light to make it go away? My car rides normal, i have no problem with alignment. I posted this question because I wanted to know how to reset the EPS to make sure that EPS light was suppose to be there. Thanks for your replies.
Old Apr 14, 2003 | 12:06 PM
mas's Avatar
mas
[QUOTE]Originally posted by swtazn97
[B]I don't remember if i noticed this but...
Old Apr 15, 2003 | 06:08 PM
Billman250's Avatar
Active Streak: 30 Days
Active Streak: 120 Days
Top Answer: 1
If the steering wheel is off center, you can bet your ass that one wheel on the car is out of alignment. Even a rear wheel a fraction off on toe can throw the steering wheel of center. A centerted steering wheel should remain proportional to a centered rack, and re-splining is not the best fix. Equal adjusting of the threaded tie rod adjusters (provided the 4 wheels are in spec) is the way to go.
Old Apr 16, 2003 | 05:47 AM
Gernby's Avatar
Former Sponsor
Old Apr 19, 2003 | 09:33 AM
Billman250's Avatar
Top Answer: 1
Thanks, gernby...
Old Apr 19, 2003 | 07:43 PM
t.c.'s Avatar
Is it possible that my alignment is too strait ahead ( not enough toe-in ) cause when i am going in a straight line the car wants to go a little on the left and the second after it wants to go on the right !
Old Apr 20, 2003 | 04:26 PM
ex-eclipse's Avatar
my car does the same as t.c. is saying. especially when i am almost to a stop. i notice it more on certain roads but it always does it. and now that i have got new wheels and tires it does it so bad i can barely keep the wheel and car straight when braking. does any one know why.
Old Apr 20, 2003 | 05:02 PM
t.c.'s Avatar
[QUOTE]Originally posted by ex-eclipse
[B]my car does the same as t.c. is saying.
Old Apr 21, 2003 | 05:43 AM
Gernby's Avatar
Former Sponsor
It sounds to me like you lowered your car, and didn't get it aligned after. Lowering the car increases the camber and changes the toe and caster. I don't know whether the toe or caster will change +/-, but I think toe out would make it more "twitchy", especially at the rear.
