How to fix this crack?
Old Aug 22, 2016 | 07:18 AM
S2005x's Avatar
Default How to fix this crack?
Bought the car like this. Missed this while inspecting it.
Not a big deal to me, as you can't see this unless you stick your head down there, but when the A/C is on, it drips water from this hole/crack...
Not sure if the part is easily replaced, or if I can just stick some black RTV in it to seal the hole, or if there are better options.
Looking for advice! Thanks in advance!
Old Aug 22, 2016 | 08:15 AM
SamySnead's Avatar
Any spare pieces of black plastic around? If so, match a piece up and carefully melt it on to the area with a soldering iron. Might be able to do it without an extra piece of plastic but hard to tell how deep it is from a photo.
Old Aug 22, 2016 | 08:30 AM
Seattle2k's Avatar
find an epoxy that is compatible with that type of plastic. I believe most of the plastic parts are polypropylene, which many epoxies will not adhere to. If you can remove the part, there will be a plastic code on it probably "PP"
Old Aug 22, 2016 | 09:23 AM
S2005x's Avatar
Thanks for the replies!!!
I'm not sure how easy it would be to remove. I think you're right about it being polypropylene though. It feels like the same plastic.
I'll swing by advanced auto parts tonight, and look for some plastic epoxy.
I have a shit ton of bondo left over from other projects, but it's bright orange :\
Old Aug 23, 2016 | 12:28 PM
rrounds's Avatar
This will fix the leak
http://www.dap.com/dap-products-ph/a...esive-sealant/
I've used it on all sorts of materials and fixed them all with no leaks.
ROD
Old Aug 24, 2016 | 04:53 AM
S2005x's Avatar
Thanks Rod!
omgitsoop
May 29, 2025 06:07 PM
neoarroyo
Oct 23, 2007 07:42 AM
the dumontster
Aug 10, 2005 05:37 AM
caramsey
Mar 1, 2004 10:11 AM
lostsol
Dec 13, 2002 06:20 PM
